Skoda Octavia 3 1.8tsi 4x4 combi
- skodko
На диагностика не записва ли грешка?
- Гараж: VW Arteon 2.0TSI
@skodko
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: -------------- Dataset Number: 5E0036t____ 0008
Coding: 03EA02003F010000
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFS_VW37.rod
VCID: 402460257B5661362B-8014
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
2 Faults Found:
5256213 - Front Left Ride-Height Sensor
C1034 15 [10001001] - Open or Short to Plus
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 7
Mileage: 207718 km
Date: 2025.03.03
Time: 15:38:45
9574400 - Bulb for Low Beam Headlamp Right
B1218 00 [00001000] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 34
Reset counter: 45
Mileage: 210809 km
Date: 2025.04.22
Time: 12:22:46
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86582207141916 Dataset Number: 5E0063t____ 0060
Coding: 0C021B56C24722FB4FE44004001C17080400000000000000000000000000
Shop #: WSC 73430 790 00125
ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
ROD: EV_BCMBOSCH_013.rod
VCID: 795BD6C85F35BBA763-802C
Wiper motor control module:
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 140708 041 0570
Serial number: 140711195236
Coding: 065DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y14M07D24H09M31S26
Coding: 00885D
Humidity sensor: interior:
4 Faults Found:
542485 - Databus
U1121 00 [00001000] - Missing Message
[Motor_18 Datenbus fehlende Botschaft]
6154 - Bulb for Rear Right Turn Signal
B11EB 15 [00001000] - Open or Short to Plus
6922 - Bulb for Low Beam Headlamp Right
B1218 15 [00001000] - Open or Short to Plus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 40
Reset counter: 45
Mileage: 207019 km
Date: 2025.02.15
Time: 10:29:16
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): On
Status Bremslichtschalter (CAN): On
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: g ltiges Funktelegramm
Voltage: 14.6 V
Outside temperature: 7.0 C
204290 - Remote key 1
B1479 18 [00001000] - Current Too Low
Coding: 3E0000
Coding: 3E0000
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 7
Mileage: 207718 km
Date: 2025.03.03
Time: 15:38:45
Freeze Frame:
Fault Priority: 6
Fault Frequency: 34
Reset counter: 45
Mileage: 210809 km
Date: 2025.04.22
Time: 12:22:46
Coding: 065DDD
Coding: 00885D
4 Faults Found:
542485 - Databus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 40
Reset counter: 45
Mileage: 207019 km
Date: 2025.02.15
Time: 10:29:16
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.6 V
- skodko
Имаш грешка за предния сензор за ниво....
- todor87
Аджамии адашче... ![sarcastic [smilie=sarcastic.gif]](./images/smilies/sarcastic.gif)
кажи му кантара на носача, че по-лесно
Тоя кантар е 400лв )) Цеко ще пробва да намери някаква алтернатива.
Глупости. Взимай от Али и слагай. По 50-60 лв са. Сложил съм поне на 5 различни коли и няма ядове. Па и да има, те 50-60 лв са три салата в кръчмата.
Номера ти е 5Q0412521C
https://www.aliexpress.com/item/1005005 ... gJbsfD_BwE
Благодаря @JORDITO, @ЦецоNOL вече ми поръча алтернативен. Не е 60лв, но не е и 400 )) Като го сменим ще пиша.
219000 км
Водна помпа (само тя!)
Нова помпичка на чистачките.
Нов кантар.
Нова хромирана лайстна на дясна предна врата.
От всички тия неща, най-скъпа е лайстната
Преди време @JORDITO ми беше обяснил как да регулирам фаровете, понеже бяха много ниски, след смяната на кантара станаха много високи, та ще трябва да ги регулирам наобратно...
Ръждивката е топ. Ако не й мине котка път планираните дейности са задни спирачки и маховик.
Нов кантар.
- skodko
Аз предлагам да в кръстим Ръждавичка ![sarcastic [smilie=sarcastic.gif]](./images/smilies/sarcastic.gif)
Оказа се, че колата губи антифриз от някакъв тъп тройник зад перката на радиатора, та Стефан смени и него. Вече проблема изглежда решен.
Преди 10-11 месеца сменихме спирачната течност с рейсърска, ако не ме лъже паметта равенол 325+. Такова беше състоянието тази седмица, но е така от поне няколко месеца. На първото по-продължително спиране и прегряваше.
Сменихме я отново. Ще видим колко време ще изкара.
Поредна вечер на страхотни емоции с Ръждивката. Два часа и кусур тигели по Асеновградско и не само.
Сборих се с едно двулитрово мерцедесче цла45, стоково предполагам, щото ми изглеждаше че го взимам. Него го беше страх малко да раздава.
Половин час по-късно няква А6-ца 3 литра бензин ми направи къси дълги, та му раздадох и на него бинокли. Спряхме на Лукойл-а и веднага последва обичайната реакция "баа таа шкода". Поговорихме, чак помоли да го повозя с приятелката му, ама не ми се сваляха столчета, та момичето остана на бензиностанцията
Още не беше успял да закопчее колана тоя младеж и второ ауди, тоя път чипосано битурбо дизел ми направи къси дълги. Него трябваше 2 пъти поред да го бия и за капак един старт от място за да се убеди, че шкодата върви повече. На светофара бяха и двамата пътници на прозореца със същата реакция "бааа тааа шкода".
Както добре знаете, колата не е нещо особено, но носи много положителни емоции и навсякъде я посрещат с голям кеф. С тия 17-ки и убит тъмно сив цвят е идеалния слийпър.
ПС.: Смених маховика с нов маховик втора употреба
, че цената на нов ОЕ е малко прекалена, а у Царацово е пълно с изостанали части на безценица. Оказа се обаче, че маховика не е толкова проблемен колкото мислех и има нещо друго да се прави по кутията. Диагноза няма в момента, щото няма и сериозни симптоми. Само аз си в хващам чат пат в крачка ![sarcastic [smilie=sarcastic.gif]](./images/smilies/sarcastic.gif)
- SilverBullet
Аз като ходя не ми цъкат къси-дълги, а не е като да не ги закачам
После обаче им е много криво ,като разберат ,че е 1.8 4х4 ![kiss3 [smilie=kiss3.gif]](./images/smilies/kiss3.gif)
- Kiko
- Местоположение: Испания
Колата стана топ, ама това дето го правите по обществени пътища не е много топ.
До @Kiko - ТЕ са добри Момчета - винаги поздравяват
П.П.
Другите ги провокират - иначе не са такива![music [smilie=music.gif]](./images/smilies/music.gif)
П.П.П.
Мен защо никой не ме провокира, дори с предишни служебни Автомобили?
П.П.
П.П.П.
