Ултра е ниво оборудване или обозначение за двигателя 2.0 TDI 190 к.с. До колкото ми е известно е второто, и да има доста куатро с автомат.Ц-Е-Ц-О БАТМАНА написа: 26.02.2019, 21:08:25 @vermeer,
Говоря единствено и само за ултра обозначението![]()
Ауди
- vermeer
- Регистриран на: 01.07.2016, 18:50:20
Ауди
- Гараж: ***
Ауди
Всичко е точно - 8.5 е фейслифта на В8 и в анимацията е сравнен с последното поколение В9redalex написа: 26.02.2019, 21:13:37@Раничко, не и според това:
https://www.carlist.my/news/comparison- ... 1318614872
(неам идея какво е 8.5...)![]()
- Гараж: ***
Ауди
@vermeer,
2014 audi a6 tdi ultra
The German automaker, which is owned by Volkswagen Group, has announced a huge diesel push with 11 new TDI “Ultra” models, including the new A6 TDI Ultra detailed here. For starters, the "Ultra" in the TDI Ultra name is Audi’s designation for sustainable mobility that is fully available for everyday use — a long explanation for a TDI A6 that gets darn good fuel mileage while not hindering its common usability.
Standard on the ultra models is a manual transmission that makes the gear ratio somewhat taller in the upper gears. Optional on the A6 is an innovative seven-speed S tronic that further reduces the average consumption rate to 4.4 liters per 100 kilometers (53.46 US mpg) with 4.6 liters on the Avant (51.13 US mpg). This corresponds to a CO2 emission of only 114 grams per kilometer (183.47 g/mile) and 119 grams (191.51 g/mile) for the Avant. This completely redesigned dual-clutch transmission launches a new generation, distinguished by high efficiency as well as by especially fast and comfortable gear changing. The innovations include minimized internal friction, highly efficient oil supply and a centrifugal pendulum-type absorber that counteracts undesirable vibrations and allows low-noise driving at very low engine speeds. A harmonious gradation of the gears in interplay with the wide spread provides comfortable driving. The seven-speed S tronic as well as the six-speed manual transmission conducts the power to the front wheels.
Ауди
Демек 2.0 тди А6 куатро нема?Ц-Е-Ц-О БАТМАНА написа: 26.02.2019, 21:25:09 The seven-speed S tronic as well as the six-speed manual transmission conducts the power to the front wheels.
- Гараж: ***
Ауди
Това важи само за моделите, обозначени с Ultra.stefan L написа: 26.02.2019, 22:05:48Демек 2.0 тди А6 куатро нема?Ц-Е-Ц-О БАТМАНА написа: 26.02.2019, 21:25:09 The seven-speed S tronic as well as the six-speed manual transmission conducts the power to the front wheels.
Объркващо е, но е така.
Целиха и оцелиха таргет групата на служебните коли.Преди време дори пуснаха А8 на предно с 2.8 мотор , a последното има и 4цил хибрид
Ултра има и при други модели
- Performance99
- Регистриран на: 20.03.2016, 15:19:27
- Местоположение: с. Съдиево|Бургас
- Гараж: VAG
- Kaloyan_vRS
- Регистриран на: 27.01.2017, 10:00:57
- Местоположение: Sliven
- Гараж: BMW M340i xDrive G20
Ауди
Тези как са,@Ц-Е-Ц-О БАТМАНА, ти си спеца на Ауди!
Жената,мрънка искам та искам RS3
https://goo.gl/images/R5VPik
- igeorgiev82
Ауди
За Тюлето ли питаш ![sarcastic [smilie=sarcastic.gif]](./images/smilies/sarcastic.gif)
- Kaloyan_vRS
Ауди
Да, точно за него, че ми трябва едно.
- Гараж: ***
- Гараж: ***
Ауди
Ся.......Kaloyan_vRS написа: 27.02.2019, 23:38:54 Тези как са,@Ц-Е-Ц-О БАТМАНА, ти си спеца на Ауди!
Като мега ултра тетра хипер гига расист, но и обективен авто фен да споделя.
Това е чистото автомобилно порно за момента.
Абсолютно никаква конкуренция няма в съотношение цена/качество/перформънс и ъпдейти.
Просто удариха в земята всичко живо.
Легендарен 5цил мотор
Тегло под 1500кг
Кутията има отделен маслен кръг с кулер,помпа и прочее за охлаждане.
За буквално смешни пари колата става 500кс, а за още малко и 540кс и влиза в класа на Порше.Само за сравнение - софтовете за Ц63АМГ започват от 6000лв.А тук за 10 000лв колата става почти 700кс.
Постоянни 2.8 до 100 и скорост над 330км/ч.
Колата може да се извращава 365 дни в годината, защото разните М2/М3/М4 Ц АМГ и прочее са си сезонни коли на задно.
Колата в стоков вид върви наравно с 450кс РС4 Б9.
От завода се предлага с два вида изпускателна система - за кандидат немски пенсионери с три заглушителя грубо казано и такава за маняци - отворена.
Изключително изчистен кокпит.
За смешните 3000лв колата става 500кс, оборотите стигат 8000об при превключване и държи на 800нм, което е пълен скандал.
Въпроси?
- igeorgiev82
Ауди
Ц-Е-Ц-О БАТМАНА, Цецо,за новото RS3 говориш май
Колегата е постнал старото.
- Гараж: ***
Ауди
@igeorgiev82,
Ся , че Калоян е Бастун е ясно
Но постоянно я дъвчем тая кола с него и Диян@Performance99, знам какво има предвид тоз калпазанин.
Старата също е с петак, но дотам.
- Kaloyan_vRS
Ауди
@Ц-Е-Ц-О БАТМАНА, Бастун, вчера коментирахме с колега, че багажника бил малък не била колата за семейни хора, и му показвах решение на проблема,за това него постнах@igeorgiev82, правилно каза за тюлето, от там тръгна работата за снимката да е тази
Иначе за новото става въпрос.
Жената едвали ще иска повече от стейдж ОНЕ, изпускателната сигурно ще е за маняци, тя жената обича да гърми.
Въпроси... Във вторник
, което ме връща в изходна позиция да дебна шаранче, или кодиаче...![hunter [smilie=hunter.gif]](./images/smilies/hunter.gif)
