EA888 Gen.4 и периферия - какво е новото?
YYakovliev
Мнение от YYakovliev »
TVS пуснаха обобщена разбивка с разликите между новата Continental турбина и старата IS38.
Линк към цялата статия: https://tvsengineering.com/en/news/ea88 ... p2mox5DXis
Based on the data and pictures above it is quite obvious why the new Continental Turbo is able to generate more airflow compared to its predecessor, the IHI IS38. The turbo housing design is further optimized with an even smoother air path and the compressor wheel is increased in size significantly.
However, in contrary to what is expected, the size of the turbine wheel is decreased. A closer look explains how the engineers at Continental managed to increase the turbine flow, while decreasing its size. This new Continental turbocharger is equipped with the new RAAX technology which basically allows a smoother exhaust gas flow over the turbine wheel. Instead of a rather sharp transition now the exhaust gasses enter the turbine at a smoother angle allowing an increase in exhaust air flow. This allows the turbine wheel to be reduced in size which decreases the turbine wheels inertia resulting into improved turbocharger response. The improved turbine wheel design together with the increased A/R of the turbine housing, increases the exhaust gas flow significantly. This increase in exhaust gas airflow has a positive effect on the maximum available power.
The increased compressor wheel size and improved design also improves the turbocharger’s total airflow capacity. The trim of a compressor wheel affects performance by altering the airflow capacity. If all other factors held constant, a higher trim wheel will flow more air than a smaller trim wheel. Although the Continental compressor wheel trim is smaller compared to the IHI IS38, the wheel size and amount of blades is increased which allows more air flow having a positive effect on maximum performance.
Another remarkable difference that requires explanation is the turbo speed sensor port and RPM sensor it is equipped with. This measures turbo shaft speed instead of only using a modeled based value as on the previous platform. TVS used data from this sensor during software development and created an extra software safety routine to prevent the turbo from overspeeding to ensure that maximum power is achieved without sacrificing reliability and durability.
Overall the new Continental Turbocharger a great step forward for all performance enhancement enthusiasts!
Гараж: VW Arteon 2.0TSI
andreev
Мнение от andreev »
Малко нереално става вече с тези коне и нютони [smilie=sarcastic.gif]
shpeki
Мнение от shpeki »
Тези поне не лъжат за коне, даже дават малко надолу. Сега е и на промоция за известно време.
Stock: 262 HP / 306 TQ
Stage 1 91: 355 HP / 412 TQ
Stage 1 91 Low Torque: Figures Coming Soon!
Stage 1 93: 366 HP / 428 TQ
Stage 1 93 Low Torque: Figures Coming Soon!
Stage 1 E85: 394 HP / 418 TQ
Stage 1 E85 Low Torque: Figures Coming Soon!
Please Note: Some late model 2022 vehicles are equipped with a TCU Box Code version that we do not currently have support for. If you have a 2022 vehicle and would like to confirm support of your vehicle, please gather the ECU & TCU Box Code and Software Version and send them to us at [email protected] for verification. To check what your ECU & TCU Box Code and Software Version are, please use this guide here.
повече инфо
MHlebarov
Гараж: 2.0 TDi 4x4 L&K 2018
Мнение от MHlebarov »
Ебаси якото, сега остава да имаш и под ръка един Ea888 gen 4 и. да му трошиш козунака!
за 890лева караш 400 коньова каляска :D
tihich
Регистриран на: 08.05.2019, 17:42:08
Гараж: Superb Scout 2.0 TSI 280
Мнение от tihich »
Преди малко Цецо потвърди, че по рама и моята излиза с Континентал турбо.
Това ме навежда на мисълта, че Ген4 са новите 280кс. Аз поръчах 272кс в края на 2020-та и Януари 2021-ва пристигна опакована с 280кс.
Ако не беше скапаното окачване дето тропа, клопа, клати, изкарва ме извън равновеси всяка минута и т.н. - можеше да сподели да сподели същата съдба като на Явор и да се засили величествено, но уви ще си седи сток пред блока [smilie=beee.gif]
Смени окачването,има лек. [smilie=sarcastic.gif]
Даже само пружините ...
@tihich, смени го вярно това окачване. Дразните от ден едно, а има толкова варианти да го излекуваш.
tihich
Мнение от tihich »
Нямам идея къде е проблема, знам само, че при неравности по пътя се налага да намалям то таква степен, че 95% от трафика ме изпреварва ... Има нещо жестото недомислено или съм изтеглил късата клечка. Няколко пъти съм я карал в Еуратек (Дружба и Надежда) и понеже няма кардинален проблем според тях си е ОК.
Според мен проблема идва от въпросното окачване за лоши пътища - реално колата хем трябва да е висока, хем да що годе стабилна като при нормална височина. Някакъв брутален микс-боза се е получил в крайна сметка. Всеки ден си мисля за търговеца дето ми каза, че няма смисъл да я взимам с DCC ...
Човек, щом нямаш ДСС ъпгрейда е още по-лесен. Слагай едно KW и ще се родиш [smilie=music.gif]
Мнение от nmnikolov »
То принципно и DSG-то хлопа, ама него трудно може да го смени [smilie=sarcastic.gif]
Сменяш тампона и спира да ти хлопа предполагам )
lybrator
Мнение от lybrator »
tihich написа: 13.01.2023, 10:58:14 Според мен проблема идва от въпросното окачване за лоши пътища
Абсолютно същия проблем имам с Октавия 3, вече е на 182000. Откакто я взех на 140000км ми прави впечатление това, което описваш. Чел съм много за Октавии с тоя пакет включително и в Англия и на други места, всички имат същите оплаквания като мен и теб. Стига се дотам, че хора минали на Айбах (което е все пак спортно в някаква степен), казват, че колата вече вози по-добре освен, че е по-стабилна...
Затова и аз поръчах Айбах от форумния маслар, още не съм стигнал да го монтирам обаче.
По темата, някой има ли информация за Gen4 и разхода на масло, има ли, няма ли, колко е?
MHlebarov
"Форумния маслар" [smilie=sarcastic.gif]
Eибаха, които си поръчал, адаптивен ли е?
Дръж ни в течение, любопитно е.
